It is currently Fri Sep 25, 2026 6:38 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Weighting the T22 (for wakeboarding)
PostPosted: Mon Mar 31, 2014 12:13 pm
The 2419 has more top end than the 2315. They are both the same diameter 15"x12 pitch but the 2419 has a different cup that gives it more top end (less low end torque). I have had the 2315 on my last 2 A22s. We just ordered the T with the 2419 prop since it was finally an option this year.
PostPosted: Mon Mar 31, 2014 12:28 pm
I believe it's the opposite on the props, the 2419 has the most pull and lowest top end of the two. That's what I was told by Acme and Nettles Props
PostPosted: Mon Mar 31, 2014 12:50 pm
I just looked at the specs and I think your right! Woops. I think I had talked to Acme about the 2315 vs 2313 and I thought it was the 2419. Thanks cause I would have been pissed if I had changed them and gotten less torque! haha
PostPosted: Mon Mar 31, 2014 12:59 pm
the 2419, 2315, and 2313 are the same diameter and pitch, but the cups are .075, .105, .150 respectively.
I do not know what the "cup" actually does. I assume the bigger the number, the more of a concave cup it is. So the 2419 has flatter blades than the other two…. not sure if this is correct, but it is how I think of it.
I do know that I tried the 2419 on my boat and it was great, smooth and pulled well… but the 2315 got more weight up on plane… by a few hundred pounds. Never tried the 2313 but I would if given the chance.
To the OP. Your boat is beautiful. I love it. If i was in the market again, we would have a hard time choosing a new T22 or A22 for sure.
As for your weight setup, I am of no real help, but do as the others said and pull up that wedge. Throw that 800 ronix bag in the bow with your 200 lbs of lead, then move the rest of your lead (300??) and split it in half, place half behind driver under the seats and half on opposite side, even with where the tower mounts to top deck.
That wake should be money, will plane all day long. That should be about 4000 lbs i think, if the center tank is still 500 and rears 250.
If you want to drop the wedge, you will need to move the 300 lbs of lead from midship to the bow with the 800 sack and other lead. That wake will be a monster, but you should be able to get it up with the 2419 and 2315.
Pictures please :)
PostPosted: Mon Mar 31, 2014 1:13 pm
Thanks for the input Johnnydefacto. I'm a big fan of the wedge because the wake stays clean but it gives you a nice peak to boot off of. I'm going to try both tomorrow.
PostPosted: Mon Mar 31, 2014 2:08 pm
Sorry. I am mistaken. I have 2313. I have a brand new 1235 I may sell to get a 2315.
PostPosted: Mon Mar 31, 2014 3:00 pm
Question? What type of lead weights are y'all using?
PostPosted: Mon Mar 31, 2014 3:16 pm
Lead wake bags.
PostPosted: Mon Mar 31, 2014 3:36 pm
I have about 10 50lb LEAD FOOT weights. My buddy bought them about 10 years ago when that company use to sell them. I also have 4 kevlar bags that have 75lbs of tire weights in each one. Those are really nice cause they have handles on them and will conform to the compartment and not tear anything up.
PostPosted: Mon Mar 31, 2014 8:32 pm
Jared has 50 lbs bags, very nice. I have 12 of them in my boat.
LeadWake@yahoo.com He ships them to your door for about $61 dollars ($50 for the 50 lbs bag and 11 for shipping)
