It is currently Thu Nov 12, 2026 7:43 pm
 Post subject: 2014 Inland Surfer shipment
PostPosted: Thu Feb 06, 2014 6:31 pm
We are getting a shipment of Inland Surf boards in next week..
Red Rockets
Fly Boys
Keenan Surf and Skim
Swallow V2
If you have been wanting one of these get with me ASAP. They sold out last season really fast.
 Post subject: Re: 2014 Inland Surfer shipment
PostPosted: Thu Feb 06, 2014 6:40 pm
No SSPs?
PostPosted: Thu Feb 06, 2014 8:42 pm
Sweet Spot Pros? Those are not on the way.
PostPosted: Thu Feb 06, 2014 8:45 pm
Bummer, Inland Surfer Sweet Spot Pro is one of the boards I am looking at.
PostPosted: Fri Feb 07, 2014 11:52 am
I wish the Sweet spot was just a few inches longer and they dropped an inch or two off the side. Then that would be my favorite inland. I just push the nose under every now and then. Other than that I like that board the best also.
PostPosted: Fri Feb 07, 2014 4:10 pm
I have the mucus but it is too slilpery for a beginner like me. The broadcast felt like a tank. Any suggestions?
PostPosted: Fri Feb 07, 2014 5:37 pm
Dezul, I would recommend one of the 4 Skim models for you (which ever size is best for you). And then get two of the 6cm delta fins for the sides. It will be the easiest board to ride, plus it will allow you to progress a ton.
admin, have you tried the Swallow? That is basically what you described. It is a little longer and narrower, but with the same rocker line and fin configuration.
But Inland Surfer surf style boards tend to pearl easier than most boards because the rocker is completely flat besides the nose flip. But that is also why they are so fast.
PostPosted: Fri Feb 07, 2014 10:20 pm
I have tried the Swallow. Just don't like the extra length of the swallow. I want the swallow and the sweet spot to merge into a new model just for me. :)
Dezul what is the weight range for you and other riders?
PostPosted: Sat Feb 08, 2014 6:56 am
130 - 230 lbs. Lol. The gf is 140 and I am 230. :-)
PostPosted: Tue Feb 11, 2014 9:10 am
At 230 you are going to want to try the Swallow for surf style.
