It is currently Sat Nov 21, 2026 4:58 am
Post new topic Reply to topic  [ 268 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 27  Next
 Post subject: Re: Home made "Poor-gate"
PostPosted: Tue Aug 27, 2013 1:58 pm
Fit it flush as well...
PostPosted: Tue Aug 27, 2013 1:59 pm
Finished product...
PostPosted: Tue Aug 27, 2013 2:00 pm
PostPosted: Tue Aug 27, 2013 5:18 pm
Just got off the water from testing out my latest (and prolly last) DIY surfgate. This one was by far the best yet. Super clean wave and very long. Here r two pics w 750s equal at 3/4 full and center tank full.
PostPosted: Tue Aug 27, 2013 5:29 pm
How fast in those pics!
PostPosted: Tue Aug 27, 2013 5:33 pm
Beautiful! Can you give those exact dimensions/angles, cuts etc? I want to make my next ones at those exact specs.
PostPosted: Tue Aug 27, 2013 5:59 pm
Hard part will be getting the angle the paddle is mounted at. I angle that a lil to replicate the angle of the true surfgate when its deployed. I just cut the paddle to fit the hull then clamped the mount into position and drilled into place. I piloted each screw tho.
PostPosted: Tue Aug 27, 2013 6:01 pm
And the paddle size was the 12"x24", 3/4" thick high density polyethylene I ordered from amazon w the notch cut for the hull and the top and bottom corners cut to mimic the stock surfgate.
PostPosted: Tue Aug 27, 2013 7:06 pm
Thank you!
PostPosted: Wed Aug 28, 2013 11:50 am
So I wanted my gate to be adjustable to different degrees and to close up for Easier storage
