It is currently Sun Sep 27, 2026 9:27 pm
 Post subject: Front Ballast Bag Pump Location
PostPosted: Tue Jul 02, 2013 8:07 am
I noticed that my front ballast switch is no longer lighting up. This happened before when my rear pump failed. I am going to test the switch, but I likely have to swap the pump. Where is the front ballast bag pump located? I am using the PNP bags.
Oh, and what make and model comes stock in a 2011 A22?
 Post subject: Re: Front Ballast Bag Pump Location
PostPosted: Tue Jul 02, 2013 9:13 am
pump is located in the same location as your front drain plug( brass t-handle)
pump is:
Shurflo Piranha 800 GPH Aerator Ballast Pump
PostPosted: Tue Jul 02, 2013 12:24 pm
yup. screw open that 8" round access cover next to your driver seat. you will see your center and front pnp fill pumps next to your front drain T handle plug.
PostPosted: Tue Jul 02, 2013 2:43 pm
Awesome! Thanks!
Users browsing this forum: Google [Bot] and 45 guests
