It is currently Sun Sep 27, 2026 10:54 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 Post subject: Re: Wakesurfing set up
PostPosted: Thu Jun 27, 2013 12:58 pm
That is what I figured but wasn't completely sure
PostPosted: Thu Jun 27, 2013 1:50 pm
Just calibrate going across the current at 90' then it would be spot on.
PostPosted: Thu Jun 27, 2013 9:01 pm
Usually hard to have enough room to calibrate going cross current. You can just use the GPS to see the current speed while floating. Say it's 2mph. Then if you go upstream, add that 2mph to what you read on the gps to get actual water speed. Or subtract for downstream.
PostPosted: Thu Jun 27, 2013 11:22 pm
I got 4 lakes within a hour from me I'll calibrate on them :)hopefully tomorrow if storms get passed :D
PostPosted: Fri Jun 28, 2013 6:32 pm
Ok did the whole get the boat up to speed hold button down and all the gauges seemed to re boot but would not let me calibrate the speed.
PostPosted: Fri Jun 28, 2013 8:04 pm
Make sure the info is on air temp
PostPosted: Sat Jun 29, 2013 8:34 am
Air temp? I though the instructions were to have it on lake temp
:o
PostPosted: Sat Jun 29, 2013 12:40 pm
Ya check out this link
viewtopic.php?t=1779
PostPosted: Sat Jun 29, 2013 7:56 pm
Users browsing this forum: No registered users and 195 guests
