It is currently Mon Sep 28, 2026 11:23 am
 Post subject: SkySki Comptech Safety Trick Release group buy
PostPosted: Wed Jun 26, 2013 11:11 pm
There's a group buy for the Comptech safety trick release on the Malibu forum.
http://www.themalibucrew.com/forums/ind ... k-release/
Here's an install on an Axis (note the change on the anchor light).
http://axiswakeboardboats.com/viewtopic ... t=comptech
 Post subject: Re: SkySki Comptech Safety Trick Release group buy
PostPosted: Thu Jun 27, 2013 9:26 am
Thats a good price! Im still really happy with my install.
PostPosted: Thu Jun 27, 2013 9:37 am
What does this do exactly?
PostPosted: Thu Jun 27, 2013 9:45 am
You configure it to release the rope at a specific weight tension (anything between 100 - 800 lbs). It's meant to prevent injury from a rope that might wrap around a body part when you fall. If you look at the Malibu forum thread it links to another thread which has a very graphic example of what can happen.
Here's the description from their site: http://skyski.com/store/comptech-safety ... lease.html
"The Comptech Adjustable Swivel Automatic Trick Release The patented Swivel Release has been in development for over 3-1/2 years. The basic design allows riders to quickly interchange ropes by using extra swivels. The rope swivels in the three rollers located in the end of the housing. When you pull on the manual release cord these three rollers tip out and release the swivel. By pushing the swivel into the three rollers they will tip in and lock into operating position. For all you flippers this is a real load-bearing swivel and has almost no drag. A spring and plunger assembly inside the housing controls the automatic part of the release. The release pressure is infinitely variable in pressure from 100 to 800 pounds. In testing we found that an average size rider takes 150 pounds of pull to get up on a plane. Once your up the load drops to around 50 lbs. So what do you do if you want to run the release at 100 pounds? Set the adjuster to 200 pounds, get up and have the observer back the nut down to 100 pounds. Just that easy! You want to go up to 800 pounds turn the adjuster to 800 pounds and keep on riding. (Just a FYI we tested the release with a knee board and saw over 400 lbs pull across the wake. We saw spikes of over 550 lbs on wake jumps) How do you know where to set the Release load setting at? There is a gauge on the side of the Release that shows you how many pounds have been exerted on the unit. Push the white pin to zero and set the release to 800 pounds. Ride as you would normally and have someone in the boat see how far the pin moved on the graduated scale. If you never went above 300 pounds then set the adjuster at 400 lbs. and enjoy. They can even do this while you are still riding. When learning new tricks that require low line tension, set the adjuster to a lower level."
PostPosted: Thu Jun 27, 2013 9:56 am
What do you set yours on while wakeboarding?
PostPosted: Thu Jun 27, 2013 10:17 am
For WBing 500lb is plenty for me. There is a reset-able slide indicator to show hardest pull - I usually top out at 350lb. I only adjusted it lower when the kids are riding.
500lb is still going to hurt, but would save your arm.
PostPosted: Thu Jun 27, 2013 11:17 am
I'm going to jump on this group buy. With two kids riding (soon to be 3) I've been thinking about getting one for awhile. If something horrible did ever happen, I'd have a pretty hard time forgiving myself for not having picked one up prior. I work in the ER right next to my lake and have treated a few patients with rope injuries from riding. One just last week that was trying a wrapped 360 and somehow got "over-wrapped" and fell with the rope wrapped around his torso. Ended up w just some bad rope burns but could've been way worse if the driver didn't stop immediately.
PostPosted: Sat Jul 06, 2013 11:00 am
Just wanted to bump this topic. Right now there are at least 13 people which puts the discount at $585. Another 7 and the price drops to $525.
PostPosted: Mon Jul 08, 2013 7:48 am
Dave, Thanks for posting this on this site. I love to see other boat owners improving the safety for themselves, passengers and riders. For this discounted price, it helps even more.
PostPosted: Mon Jul 08, 2013 9:57 am
Thanks to everyone for participating.
We are WELL over the 20 needed for the max discount. SkySki wasn't anticipating us reaching that amount so soon, so it looks like they will be ending the group buy early and soon. I will know the actual time tomorrow, when the boss returns and I will post it up.
If you are on the fence, it's decision time! Get your email into Jake ASAP! This offer will end soon. DO NOT DELAY!
