It is currently Mon Sep 28, 2026 3:04 am
get_sum
Post subject: Re: Be sure to replace your impeller Posted: Tue Oct 30, 2012 9:51 am |
Joined: Fri Aug 17, 2012 1:18 pm Posts: 435 Location: OKC
Just removed mine. I left the housing and pump, on the boat, but took off the engine side panel and the rear (smaller) panel as well. I sat in the storage bay on top of the tank and stuck my head in on the side. Sprayed a little wd-40 on it and 5 min later pulled it out with needle nose pliers and worked it out the rest with two flatheads. I'm gonna leave it off until spring time and put the new one in then.
get_sum
Post subject: Re: Be sure to replace your impeller Posted: Tue Oct 30, 2012 9:56 am |
Walter
Post subject: Re: Be sure to replace your impeller Posted: Tue Oct 30, 2012 9:10 pm |
thanks for the reminder, I need to do that this year, I rolled the dice and skipped it last year but I think i'll go ahead and do one this time around
bmill6154
Post subject: Re: Be sure to replace your impeller Posted: Thu Feb 14, 2013 10:02 pm |
| Boater |
Joined: Sat Jul 02, 2011 3:47 pm Posts: 40 Location: Houston, Tx
Walter
Post subject: Re: Be sure to replace your impeller Posted: Tue Jun 25, 2013 7:16 pm |
Just did mine again yesterday, this time I tried get_sums way, I took out the side panel on the starboard side and removed the rear smaller panel by the muffler, It only had 2 screws on it, then I pulled out the vent hose and just laid over and got to all 4 screws on the pump cover easy, popped it out with 2 flathead screwdrivers and slid the new one in, finished in less than 30 minutes, I'll be leaving it on from now on.
AJWest
Post subject: Re: Be sure to replace your impeller Posted: Tue Jun 25, 2013 8:30 pm |
Replaced mine 25 hours ago. Cheap insurance for a stress free season.
devilmike90
Post subject: Re: Be sure to replace your impeller Posted: Fri Jul 05, 2013 1:26 pm |
| Newbie |
Joined: Mon Apr 22, 2013 10:37 am Posts: 25 Location: Ottawa, Ontario
devilmike90
Post subject: Re: Be sure to replace your impeller Posted: Fri Jul 05, 2013 1:28 pm |
| Newbie |
Crap they don't ship to Canada!
Users browsing this forum: No registered users and 42 guests |
