It is currently Thu Nov 19, 2026 11:16 pm
 Post subject: Front sac hose and pump upgrade
PostPosted: Thu Jun 20, 2013 1:58 pm
I decided to upgrade the front sac to fill with 1" hose and a 1200 GPH pump to improve fill time. I also wanted to add a check valve to prevent the bag from draining on its own.
Parts:
Attwood Corporation 1200 Cart Aerator Pump with 1-Inch NPT - with the 1" NPT model of the pump its easier to adapt to the hull valve.
PVC parts from home depot to connect the pump to the hull valve - I didn't want to replace the hull fitting and I figured there would be pressure at that point to overcome the restriction.
Hose - Shields Series 141 Multiflex Hose 1" ID - I wanted something clear and it's able to bend with a fairly tight radius. I didn't like the way it fit onto the fittings so I'm not sure I would use it again.
Fittings - came from boardstop.com - I used the process here to remove the 3/4 fitting - viewtopic.php?t=137&p=9403.
WeatherPack 2 pin (14-16 awg) kit - I got these from http://performanceplusconnection.com/. Ideally you get a special crimping tool for these. I used a regular crimping tool and it was a pain to do.When I replace the reap pumps I'll also solder the connection.
Bosworth check valve - not barbed, but about 1/2 the price of the Fly High check valve.
Last edited by Dave.Mishchenko on Thu Jun 20, 2013 2:14 pm, edited 1 time in total.
 Post subject: Re: Front sac hose and pump upgrade
PostPosted: Thu Jun 20, 2013 1:59 pm
I drilled out a 2" hole to re-route the fill hose using the same path as the drain hose.
PVC adapters to allow the pump to fit the existing hull valve.
PostPosted: Thu Jun 20, 2013 2:06 pm
These are the Weather Pack terminals on the pump wires waiting assembly into the terminal.
Check valve / hose / and quick connect fitting.
PostPosted: Thu Jun 20, 2013 2:09 pm
Connected to the bag
Image of the pump and PVC adaptec assembly. The pump can be replaced on the Tsunami pumps without removing the housing and there's enough clearance to do that.
PostPosted: Thu Jun 20, 2013 2:10 pm
PostPosted: Thu Jun 20, 2013 2:23 pm
Outstanding! Doing all this in that small confined area.
PostPosted: Thu Jun 20, 2013 4:36 pm
Why didn't you just run one of these pumps? It has a 3/4" inlet and a 1" outlet and still flows 1100 gpm. http://www.wakemakers.com/rule-aerator- ... -1100.html
I know it's not quite the 1200 of the tsunami but its pretty close and you wouldn't have had to put those adapters in there.
PostPosted: Thu Jun 20, 2013 7:53 pm
If I had known about them I would have probably ordered them instead.
PostPosted: Tue Jun 25, 2013 5:30 am
Great job! Where did you get that check valve? Boardstop? I still need one - desperately.
That is an interesting pump - thanks for sharing. $50 upgrade would help fill my 1100 in the surf corner at-least 50% quicker...
PostPosted: Tue Jun 25, 2013 6:36 am
The check valve came from West Marine - http://www.westmarine.com/webapp/wcs/st ... sNum=50649
Users browsing this forum: Google Adsense [Bot] and 10 guests
