It is currently Sun Feb 08, 2026 12:15 am
 Post subject: Foam bottoms for cup holders
PostPosted: Tue Jun 18, 2013 11:39 pm
Soooooo....2013 A22 with stainless cup holders is what I am working with. Boat is two weeks old and has about 14 hours on it.
Every single one of the foam bottoms to the cup holders appears to just be shriveling up and folding on itself. Is everyone having this same issue? It's more annoying to look at than anything as it doesn't affect using the cup holders at all...but I can't imagine what he remedy will be when I talk to my dealer about it
 Post subject: Re: Foam bottoms for cup holders
PostPosted: Wed Jun 19, 2013 4:19 am
I have about 22 hours on mine and do not have the issue.
Jason
PostPosted: Wed Jun 19, 2013 6:13 am
Cosmetic issues are covered - The remedy should be replace the cup holders under warranty.
PostPosted: Wed Jun 19, 2013 8:01 am
same issue here. A22 2013 Axis
Lake Lanier Georgia
Axis A22 2013
PostPosted: Thu Jun 20, 2013 8:52 am
Jason do you have a 2013? I wondering if they just switched the foam up for some reason.....just looks tacky but doesn't affect anything so ill bring it up when I have it back at the dealer next time.
PostPosted: Thu Jun 20, 2013 11:04 am
Yes 2013 delivered late May.
I checked again last night and don't have the issue. I also don't use them, maybe condensation from a cold cup causes the adhesive to let go?
PostPosted: Thu Jun 20, 2013 1:21 pm
Get it covered under warranty. The dealer might just glue them back in or have Axis replace them. If it is a common problem the dealer or axis will have seen this problem already.
PostPosted: Fri Jun 21, 2013 9:27 pm
Same issue. Might cut out some grip tape to replace the foam.
Users browsing this forum: No registered users and 76 guests
