It is currently Fri Sep 25, 2026 5:20 am
 Post subject: Wheel size for tricked out trailer?
PostPosted: Sat Jun 15, 2013 3:23 am
Anyone have one that can tell me what size wheel and tire is on it? Are the fender wells wider than a non tricked out trailer? If so, what size wheels have you all put on a regular trailer??
 Post subject: Re: Wheel size for tricked out trailer?
PostPosted: Sat Jun 15, 2013 7:02 pm
I'll check for you later, I know they are 18" wheels
PostPosted: Sat Jun 15, 2013 11:19 pm
sweet, if you can, measure the width of the fender too? im curious if its wider than a standard trailer...
PostPosted: Sun Jun 16, 2013 3:27 pm
Tires are 255/45ZR18. The fender is 11" wide and the tire still stick out very slightly.
PostPosted: Sun Jun 16, 2013 7:06 pm
Ferral, do you happen to know the backspacing on those 18's? I am assuming they are something like 18x7"?
PostPosted: Sun Jun 16, 2013 8:24 pm
I don't, I just happened to be outside with a tape measure earlier. Are wheels generally marked for the info you want? If so tell me where and ill look. Or if its something I can measure, let me know where to measure.
PostPosted: Mon Jun 17, 2013 1:46 am
if you could measure the width of the wheel maybe? im pretty sure its a 18x7 it could be wider i suppose. im really just curious if whatever wheels they are will fit on a standard trailer. may be easier to just call the dealer and ask.
