It is currently Thu Sep 24, 2026 7:28 pm
 Post subject: Height of tower mirror mount when folded down
PostPosted: Tue Jun 04, 2013 11:33 pm
Curious if anyone knows if this mirror arm becomes the high point (as opposed to the windshield) when the tower is down? Anyone know by how much?
New owner of a 2013 A22 and determining if I could use one as its a tight fit already getting into my garage.
Thanks!!
 Post subject: Re: Height of tower mirror mount when folded down
PostPosted: Wed Jun 05, 2013 6:28 am
I'm not sure how much but another member has to take his mirror mount off every time it goes in his garage, I put mine under a 7' door and I have about 3-4" clearance going in, I opted for the windshield mount PTMedge mirror
PostPosted: Wed Jun 05, 2013 7:36 am
Ae you saying a couple inches of clearance with the windshield mirror?....or that's what you had prior to changing to the windshield mirror?
PostPosted: Wed Jun 05, 2013 7:57 am
That's with the windshield mirror folded down, total clearance to the top of the glass is 3-4". I can post a pic tonite
PostPosted: Wed Jun 05, 2013 10:31 am
I have an A20 with the mirror mount arm and it just fits under my 8' door with the tower down. I don't have to do anything to the arm and barely brushes the weather stripping on its way in. I also have the single axle trailer, so I'm not sure if their is a heigh difference on the tandem axle.
-Pat
PostPosted: Wed Jun 05, 2013 10:27 pm
Damn.....well my door is 7 ft so I doubt it will fit. The dealer said it breaks away for this reason. In pics it looks like bolts.....does it really break away easily?
PostPosted: Thu Jun 06, 2013 6:57 am
It is pretty easy to take off.. just at the top of the base tower clamp there are three allen head bolts, no big deal. Also, I can leave it on and squeeze under my 8' door by simply pushing it down about 3 inches (rotates on the tower slightly).
PostPosted: Thu Jun 06, 2013 2:28 pm
i just leave the arm a little loose and then push it down to below the windscreen my door is 7ft and it clears just fine
PostPosted: Thu Jun 06, 2013 2:51 pm
mine fits in the open behind it by about an inch
PostPosted: Fri Jun 07, 2013 7:51 pm
This is what I mean by leaving the arm loose and pushing it down
It goes below the wind screen
Users browsing this forum: No registered users and 67 guests
