It is currently Mon Mar 30, 2026 12:13 am
[ 6 posts ] |
SomeYeahoo
Post subject: Temperature Gauge Accuracy Posted: Sat Jul 09, 2016 7:44 am |
How accurate are your temperature gauges (air/water)? Mine don't seem to be all that accurate. They seemed to be more accurate in the past, so I asked the dealer to calibrate them when I dropped it off for them to work on the surfgate issue. How high should my expectations be?
gibbs114
Post subject: Re: Temperature Gauge Accuracy Posted: Sat Jul 09, 2016 8:18 am |
Joined: Wed Nov 30, 2011 8:08 pm Posts: 770 Location: West Tennessee
Mine are close. Water is almost right on. Air temp is close but normally shows hotter. I've had 4 boats with temp gauges and it's been the same on all of them. Air temp is tough when in the hot sun all day much better when moving.
_________________ Gibbs Malibu 23 LSV
motonet
Post subject: Re: Temperature Gauge Accuracy Posted: Sat Jul 09, 2016 10:07 am |
My water seems pretty accurate but the air is way off
Dman726749
Post subject: Re: Temperature Gauge Accuracy Posted: Sat Jul 09, 2016 10:34 am |
Joined: Sat Jul 20, 2013 9:28 am Posts: 78 Location: Avon In
my water temp is close, except when its cold, then it reads high, air always reads a little higher than normal.
_________________ 2013 A20
SomeYeahoo
Post subject: Re: Temperature Gauge Accuracy Posted: Wed Jul 13, 2016 8:23 pm |
Dealership says mine is working fine. Hmmm....
moto0x
Post subject: Re: Temperature Gauge Accuracy Posted: Fri Jul 15, 2016 7:00 am |
Is there a way to calibrate them. My water temp is about 10 low
[ 6 posts ] |
Users browsing this forum: No registered users and 56 guests |
