It is currently Fri Apr 26, 2024 6:40 am
[ 3 posts ] |
Author |
JLyonz
Post subject: Axis A22 engine temperature Posted: Thu Aug 02, 2018 9:24 pm |
Hey guys I've been cruising the forums but I'm not finding the answers I am looking for so I'll start a new thread.
I have a 2014 A22 with the 409 monsoon. Usually my gauge reads 158-163 deg at all times. I've recently noticed that when idling around the temp climbs to 184 and the will drop back to 160 when the rpms climb past 2500. I was thinking the impeller was to blame even though it was changed about 40 hrs ago I pulled it out anyway and it looked like new still. I was wanting to check the thermostat but was not sure where it was located. Anything else you guys recommend I check out? Thanks in advance for the help!
Sent from my SM-G930W8 using Tapatalk
Top |
elc
Post subject: Re: Axis A22 engine temperature Posted: Tue Aug 07, 2018 5:37 pm |
Team Axis |
Joined: Tue Apr 27, 2010 11:31 am Posts: 327 Location: Anaheim hills, ca
Sounds like there could be grass or something stuck in the strainer. I had this issue quite a bit, I ended up adding an in line strainer that was easily accessible.
Top |
JLyonz
Post subject: Re: Axis A22 engine temperature Posted: Fri Aug 10, 2018 11:37 am |
I did check the strainer and it was all clear. I also checked the small pipe that connects each of the heads to togeather and then has a hose running to the exhaust. It had a decent amount of sediment in there so I cleaned it out. It helped a bit but not much. I believe I have blockage somewhere else just not sure where yet I'll have to start pulling hoses and checking things out!
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 70 guests |
