It is currently Tue Nov 18, 2025 10:02 pm
 Post subject: Tire pressure
PostPosted: Fri Apr 12, 2013 1:26 am
I have Nexen n3000 tires on my trailer and they say max 150psi on them. That seems really high. What pressure should i be running?
 Post subject: Re: Tire pressure
PostPosted: Fri Apr 12, 2013 7:46 am
I would look at that psi again more then likely its only 50 ...... look at your trailer/boat manual it should tell you a specified tire psi .... i would set it at 45 to 50 psi
what size is it i can look up spec
PostPosted: Fri Apr 12, 2013 8:53 am
Between 40-50 is good, definitely not 150, most small radials like these are 35-44
Nexen N3000
Specs/SizeDescriptionFeatures/BenefitsFitments
Specs/SizeSIZE 255/45ZR18XL
UTQGL 340 AA A
SERVICE 103Y
SUPPLIER 12054NXK
MIN RIM WIDTH 8.0000
MAX RIM WIDTH 9.5000
OUTER DIAMETER 27.05
Single Max Load lbs 1929@50
Dual Max Load lbs NA
RPM NA
TREAD DEPTH 10.00
SHIP WEIGHT 30.050
SPECIAL NOTES
DescriptionNexen N3000 tires are made for ultra high performance driving. Featuring directional wide aqua groove design, these speed-rated tires resist hydroplaning allowing you to handle wet conditions. With a new shoulder design, this tire improves cornering stability. For high speed driving performance in wet or dry road conditions, the Nexen N3000 is a quiet tire that is designed to last.
FeaturesArrow center rib designShoulder designAggressive type lateral groovesDirectional wide aqua groove design
BenefitsHigh speed driving performanceUpgraded cornering stabilityAnti hydroplaning
This tire has not been identified as a replacement for Original Equipment.
Print DetailsEmail Details
PostPosted: Fri Apr 12, 2013 10:21 am
Awesome... thanks for the quick reply guys :-D
Users browsing this forum: Majestic-12 [Bot] and 69 guests
