It is currently Wed Jul 15, 2026 9:53 pm
 Post subject: Almost sank the boat tonight!!
PostPosted: Thu Aug 30, 2012 8:58 pm
I was wakesurfing tonight and all of the sudden we heard a clunk and the boat would not move. We opened up the transmission cover after checking to make sure the prop was still on the boat and there was water coming in from the drive shaft and the drive shaft had came unhooked from the transmission. We were in the middle of the lake and we were the only one out there. After about 45 minutes of the bilge pump running it stopped working and would not pump anymore and the water continued to pour in. The water was up to the bottom of the floor by the time we got it on the trailer. It was a little bit on the stressful side. Does anyone know what would cause the driveshaft to come apart from the transmission. The entire thing slid down and if it had not been for the rudder being there everything would have been at the bottom of the lake. To top things off when the prop hit the rudder it put a big dent in the edge of one of the blades.
 Post subject: Re: Almost sank the boat tonight!!
PostPosted: Thu Aug 30, 2012 9:23 pm
Holy sh$t!!! Should of disconnected the hoses from the ballast drain pumps and turned those on.
PostPosted: Thu Aug 30, 2012 9:40 pm
wow. sorry to hear that but I am glad you got it back on the trailer. I am betting your 4 bolts either loosened and fell out and/or sheered off of your coupler from the shaft to your transmission. I have been reading a few threads about this on wakeworld, of guys finding random bolts in their bilge, track it down to their driveshaft/tranny coupler. This reminds me that I am going to check and torque these bolts down before I go out again.
let us know how it goes
PostPosted: Thu Aug 30, 2012 9:49 pm
Crazy!!! Glad you saved it! Let us know what happened when you find out all the details
PostPosted: Thu Aug 30, 2012 10:33 pm
What year Axis and how many hours?
PostPosted: Fri Aug 31, 2012 12:31 pm
The boat is a 2012 with about 80 hours on it. I called the dealer last night and they have never heard of anything like this happening. I will keep everyone informed with what I find out. It was pretty scary. Luckily I was just on a small lake but the three of us that were swimming pulling the boat are very sore today. It was a heck of a workout.
PostPosted: Fri Aug 31, 2012 1:45 pm
Great tip on using the ballast drain pumps AJ. I'd be in a panic for sure- glad you got her out in time.
PostPosted: Fri Aug 31, 2012 1:50 pm
I tried to get the ballast pumps to start pumping but I could not get them undone.
PostPosted: Mon Sep 03, 2012 9:33 pm
That is why I like having a regular pump on the boat. Never know when they will come in handy.
PostPosted: Tue Sep 04, 2012 4:24 pm
I've used my tsunami to purge water from bilge. Had a pnp sac in rear that fitting came loose.
