It is currently Sun Jul 26, 2026 12:25 am
 Post subject: High Altitude Colorado
PostPosted: Tue Jun 05, 2012 1:05 pm
So I just got my A20 with the 335hp and high alt prop but with all the plug and play full and wedge down this thing wont plain. It seem it will only get to about 15 mph. Is it because of the alt?
With wedge up there is no problem. Any ideas?
PostPosted: Tue Jun 05, 2012 1:28 pm
I had the same problem but I also had 11 peeps in my a20. Put the wedge up and no problems. Seems you have a choice to make the peaky with the wedge down and less weight or mellow no wedge and all ballast. If its the alt I haven't a clue...
 Post subject: Re: High Altitude Colorado
PostPosted: Tue Jun 05, 2012 2:02 pm
Sounds like you may need a prop, at that altitude I'd go with the acme 2079 or something similar.
http://www.boardstop.com/product_info.p ... ts_id=5290
The 5 blade or 1615 won't be enough of a difference to benefit if you're having trouble with the high altitude as it is.
I edited the web link, definitely get it from the boardstop and support the site, that and the price is cheaper too! sorry admin wakeprops is the first one that pops up on a google
PostPosted: Tue Jun 05, 2012 11:24 pm
We put the 2315 on our loaded down MXZ and it really gave us everything we needed on the low end. It is a 15" prop.
http://www.boardstop.com/product_info.p ... ts_id=6035
We have not tested the 15" prop on the Axis. anyone else try the 2315?
