It is currently Mon Sep 28, 2026 6:23 pm
 Post subject: Coolant temp warnings LS3
PostPosted: Mon May 21, 2012 8:11 am
I don't know how many other LS3s we have here but I have about 15 minutes of 5mph and idling before I get out of the marina. Almost every time I pull it out, I get coolant temp warnings just before I'm out of the 5mph. It's up at 185* Once I speed up, it'll drop down to 165-170* and it's good.
Anyone else?
Axisowners
 Post subject: Re: Coolant temp warnings LS3
PostPosted: Mon May 21, 2012 9:19 am
Does this happen when you go back in as well, or just on way out?
PostPosted: Mon May 21, 2012 9:32 am
Just on the way out.
Axisowners
PostPosted: Mon May 21, 2012 11:07 am
The warning buzzer needs to be raised to 200deg, it sounds like its just coming on when your thermostat is opening. Probably have to get the dealer to put in a 160 instead of the 180. Or reflash the computer to raise the warning temp.
PostPosted: Mon May 21, 2012 11:18 am
If you search on LS3 overheating you'll find a few threads such as the following. It seems to be a challenge with the LS3 which is made worse if you have a heater. Although on the following threads their thermostat is set higher. Seems like you have an issue that Axis/Indmar need to fix.
http://www.themalibucrew.com/forums/ind ... ntry413987
http://www.themalibucrew.com/forums/ind ... akesetter/
PostPosted: Mon May 21, 2012 12:01 pm
Thanks, didn't think to check the bucrew site.
Sounds like I fit right in with those others. I'll check with the dealership tomorrow when they open.
Axisowners
PostPosted: Mon May 21, 2012 12:18 pm
My ls3 does not do this.
PostPosted: Mon May 21, 2012 12:20 pm
Yours is quite a bit newer and maybe has that booster pump kit already installed?
Axisowners
PostPosted: Fri May 25, 2012 7:52 am
I have almost 200 hours with the similar situation to get out of the marina. Mine stays between 155-158.
PostPosted: Fri May 25, 2012 8:51 am
Last time I came out of the marina (Wednesday) I made an effort to hustle out and I beat the alarm... Got up around 170 before I made it out of the 5mph but it cooled down as soon as I took off.
Axisowners
