It is currently Mon Aug 25, 2025 9:19 am
 Post subject: 2011 A22 Vandall Ballast question
PostPosted: Sat Jun 01, 2019 7:10 pm
My 2011 has the hard tanks plus 1100 in the rear. When I start filling, it fills for a few minutes then water starts coming out the drains, while it is filling the bags. I understand that it fills the hard tank first then fills the bags but it’s kind of a pain. I have resorted to plugging the drains with corks while we surf do water stays in. Any thoughts on how to fix this? I’m thinking of just bypassing hard tanks all together, at least I’ll know I’m fully empty.
 Post subject: Re: 2011 A22 Vandall Ballast question
PostPosted: Sun Jun 02, 2019 12:28 pm
i am having different issues but there is a valve that will allow water to enter hard tank only or hard tank and bag.. make sure its open to the PNP bag.
PostPosted: Sun Jun 02, 2019 6:54 pm
Can you tell me where I might find this valve?
PostPosted: Mon Jun 03, 2019 6:00 am
sure the ball valve that i have is located in the engine compartment. open up your hatches.. locate the spot where the plug and play( Y's )one will go to the hard tank fill and the other will prob go to the top of the bag fill.. mine is a plastic black handle.( technically its mounted to the backside of the bench seat.. also look for severely kinked hosing going to your bag.
also, go on FB and join the axis malibu page. the response time and the help on there will be better...
PostPosted: Mon Jun 03, 2019 7:37 am
Thank you - I’ll take a look
PostPosted: Mon Jun 03, 2019 10:20 am
I don't remember having that switch on my 2012 a22, but I definitely have it on my 2014. My 14 a24 will sometimes purge water while filling, but it still fills fast enough. Please let us know if you find a solution. Also, with 1100's in the back of that a22 do you get much length to the wave? What speed do you surf?
PostPosted: Tue Jun 04, 2019 3:46 pm
Do this viewtopic.php?f=15&t=3082&start=0
And all your issues will be fixed
Users browsing this forum: No registered users and 117 guests
