It is currently Sun Aug 24, 2025 8:17 pm
 Post subject: Indmar Pro Sea Strainer
PostPosted: Sat Jul 15, 2017 11:39 am
My 2015 A20 sucks up too much debri and constantly overheats. Bought an Indmar Pro Strainer and installed it. Here are some pics if anyone is thinking of installing it.
Tools- Hacksaw, flat head screwdriver.
When you cut out a portion of the intake hose the hacksaw works great, be careful of the wire- its sharp when you cut it and got me a couple times. Error on the side of cutting too little of the hose.
Review- Works great, easy to install, can clean out debris in 30 seconds and be boating again. Hose attachment is great for dry starts.
Only con I can see so far is the plastic it's made out of. Not sure how long it will last before cracking. Cost was about $90ish for the entire project.ImageImage
 Post subject: Re: Indmar Pro Sea Strainer
PostPosted: Sat Jul 22, 2017 6:58 pm
i have had mine for a two summers and it works great. easy cleanup and great for winterizing.. where do you surf? the water is so brown?
PostPosted: Tue Aug 08, 2017 9:47 pm
We surf / boat at Lake Nacimiento. It's near Paso Robles in Cali. The Strainer has been a welcome addition! Saving me a ton of busted knuckles trying to get to the oem debri screen.
PostPosted: Thu Nov 30, 2017 11:06 am
Good to know. Thanks for sharing your experiences Rmil. I might get it myself.
This phenq review is superb and very detailed too.
PostPosted: Thu Oct 11, 2018 9:04 pm
Can you please explain the routing for me? Isn't the intake supposed to route to the water pump? I would like to tackle this project before next winter...
2018 T22
PostPosted: Mon Oct 15, 2018 1:30 pm
The water comes in and goes thru the v-drive, then the transmission cooler then back to the water pump.
