It is currently Wed Oct 28, 2026 7:22 am
 Post subject: Installing bags on 15 T23 with plug and play
PostPosted: Wed Jun 06, 2018 7:31 am
I just ordered bags from my local dealer and should have them today. Couldn't find info out there on installing on a newer boat with the plug and play. Any info out there? Thanks!!
 Post subject: Re: Installing bags on 15 T23 with plug and play
PostPosted: Wed Jun 06, 2018 9:51 am
Its pretty simple. If the boat doesnt have any bags currently then the lines will have plugs in them. Take the plugs out and hook them to the bags. Bag should be marks "front" or an arrow. Put the "front" to the bow of the boat and your all set. It took me less than 5 minutes. Usually the first time out filling the bags you will need to move the bags around so they fill evenly and are centered in the lockers. Shouldnt have to touch them again.
PostPosted: Thu Jun 07, 2018 7:16 am
Isn't there something odd with the bow sac?
PostPosted: Thu Jun 07, 2018 9:22 am
Kinda. There should be 3 hoses that all connect to a "Y" fitting in the bow now. One hose it the fill, ones the drain, and the other is vent. Remove all three from the "Y" and connect them to the ports on the bag. I cant tell you which one is which as far as the hoses in the boat, but you should be able to trace them back to pumps etc. You will not reuse the "Y" fitting.
PostPosted: Thu Jun 07, 2018 1:20 pm
Thanks!!
