It is currently Sat Jul 11, 2026 3:46 am
 Post subject: t22 heater core
PostPosted: Fri May 25, 2018 12:31 pm
So i got a new heater core, perfect match.... did not take a pick before taking out the old one.. does it matter which way the hoses hook up ? or a way to tell which hose is the return.
I know this is a simple process and i screwed up..
 Post subject: Re: t22 heater core
PostPosted: Fri May 25, 2018 3:36 pm
I actually just called them to verify the proper way to install their low idle wye. I asked about heat exchanger flow direction for you. Flow direction does not matter. So just hook your hoses up. It’ll work as it did before.
2016 A22
Users browsing this forum: Google [Bot] and 30 guests
