It is currently Fri Oct 23, 2026 3:16 am
 Post subject: Speed Control Disables when going over rollers
PostPosted: Thu Oct 26, 2017 8:03 am
I have a symptom I'm trying to solve on my Axis 2011 A20. When we are riding with the speed control on (paddle wheel version), and we go over significant rollers, either slowing down to about 12mph or not, the speed control stops controlling the throttle and doesn't pick back up till we stop and start again. The actual speed keeps going way past the set speed and won't beep to engage, which makes us (usually my wife) have to resort to manual speed control. At that point we usually stop, let it idle for a couple seconds in neutral and start again, which it starts working again.
There is a reason why they call speed controllers "marriage savers" hahaha
Does anyone have an idea what can be causing this or any experience with this similar symptom?
 Post subject: Re: Speed Control Disables when going over rollers
PostPosted: Thu Oct 26, 2017 8:48 am
Seems like I remember reading something in the manual for my ‘17 A22 that speed control will disengage if you deviate more than 3mph from the set speed.
I have not experienced your scenario but I know mine does not like to be turned on or off while underway. Ie done surfing and you head back to the dock. If I turn it off underway, the dash says it’s off but speed control won’t disengage. Gotta throttle back to almost 0 and the go again. Probably a safety feature.
