It is currently Thu Nov 06, 2025 2:00 am
[ 6 posts ] |
Stewy209
Post subject: Completely dead Posted: Sun Sep 03, 2017 8:44 am |
I turn the ignition and nothing happens,the batteries are on...... any ideas?
pilotflying
Post subject: Re: Completely dead Posted: Sun Sep 03, 2017 10:18 am |
Joined: Thu Oct 30, 2014 7:24 am Posts: 88 Location: Germany
Is it in gear? It won't start then....
_________________ 2014 A22
dustinjean
Post subject: Re: Completely dead Posted: Sun Sep 03, 2017 10:26 am |
Joined: Wed Sep 03, 2014 5:19 am Posts: 457 Location: Mt. Washington, KY
Did the kill lanyard get pulled on?
_________________ 2014 A24
A22owner
Post subject: Re: Completely dead Posted: Tue Sep 05, 2017 5:47 am |
Wilbur
Post subject: Re: Completely dead Posted: Sat Sep 09, 2017 11:59 am |
Make sure your battery cables are tight. I had mine randomly come loose on both batteries at about 200 hrs
WayneTuttle
Post subject: A couple of questions... Posted: Sat Sep 09, 2017 12:38 pm |
Joined: Sat Jun 21, 2014 6:27 pm Posts: 178 Location: Parker Strip, AZ
By completely dead I suppose you mean nothing happens at all. But I am not sure. So here is a list of questions that will help to tie this down a little better.
If you turn the key to the ON position, does anything come on? Gauges? How about the radio? If nothing comes on, the problem is between the batter and the dash board in cables, fuses, and such. Make sure you also verify ground cables. Use a meter to find the "open".
If the above works and the gauges wake up but the engine does not crank, check neutral safety switch and lanyard first.
With those new clues, it will be easier to guide through the trouble shooting...
[ 6 posts ] |
Users browsing this forum: No registered users and 45 guests |
