It is currently Mon Nov 10, 2025 8:21 pm
 Post subject: Rear Ballast - Removing hard tanks and running 1100 only.
PostPosted: Mon Apr 09, 2012 12:29 pm
Hey everyone.
Im new to the forum here. I just took out my new to me 2011 Vandall last weekend for the first time. Absolutly loved the wake and boat, it exceeded my expectations. It has a Raptor in it and used way less gas than I expected which was a surprise.
One thing I did experience (as it seems like everyone does) is slow draiing from the rear plug and play. I thought about it for a while and wondered if anyone has just removed the hard tanks altogether and ran just the 1100 fly highs. It seems that the bags only fill to about 900 lbs anyway, so it would make sense to just remove the tanks and let the bags fill to capacity. Then you wouldn’t have the draining issues either. Has anyone attempted this or even know if its a possibility? Let me know your thoughts.
 Post subject: Re: Rear Ballast - Removing hard tanks and running 1100 only
PostPosted: Mon Apr 09, 2012 12:46 pm
I was curious about this too. Maybe relocating the locker "Floor" above the bag to create more storage. At that point, might as well go with bigger tanks...
PostPosted: Mon Apr 09, 2012 2:12 pm
I like both those ideas. throw the 1100 in there, replace all ballast hose with 1" (still with 3/4" fittings, this will help reduce friction loss, increasing volume, reducing fill and empty times). Making a "floor" just above where the top of a full bag would be has been banging around my mind as a project too, its a great idea.
Walter... get on this and then build it for me :) just kidding, but seriously, I want to do it.
PostPosted: Mon Apr 09, 2012 5:03 pm
That's an awesome idea. I second Johnny's idea too. Let us know when u got this one knocked out Walter. :)
PostPosted: Mon Apr 09, 2012 5:14 pm
Welcome to the Axis Wakeboard boats forums.
Here's another option for slow draining rear ballast - viewtopic.php?f=14&t=552&p=3338&hilit=slow+drain#p3338.
PostPosted: Mon Apr 09, 2012 7:12 pm
I have been thinking of this for a while
Gibby
2011 A22 Vandall
PostPosted: Mon Apr 09, 2012 8:40 pm
Gibs, the metal frame/bracing that holds each engine divider would give you 2 points to attach to on the engine side, but I do not know how to brace the "floor" on the out fiberglass/hull side. I will need to climb in there and check it out.
PostPosted: Mon Apr 09, 2012 10:26 pm
I like imondi's idea, sounds faster and cheaper than trying to reengineer the rear storage compartment. That and I couldn't do it anyway, if I had 1100's in mine it wouldn't even think about getting up on plane with the air quality where I ride.....
PostPosted: Thu Apr 12, 2012 8:49 am
Ok, So I dug into the boat last night to try and remove the tanks. I could get the rear floors out but it looks like in order to get the tanks out you would have to cut them (im not ready to make that commitment). Otherewise there was no way that I could see to get them out. Its a bummer, because there is so much space back there without the tanks. The 1100 would definatly fill all the way and you would then have much deeper storage under the rear corner seats. I thought about relocating the batteries back there if removing the tanks was possible.
For now It looks like im gonna have to just add 2 more pumps to the rear to empty the bags like suggested above. Let me know if anyone else has any ideas to get the tanks out.
PostPosted: Sun Apr 15, 2012 2:34 pm
I was doing the same thing today.
1. it was a mess only getting the floor out.
It was jam in front under the side seat and in the middle under the back seat.
2. then I realize the hard tank are like glued and quite long.
So I would need to cut them.
I don t have the plug and play so I said maybe it would be the way to fill th back sac.
Me too I will reconsider unless someone here try it and said it a easy task.
