It is currently Fri Nov 07, 2025 12:38 am
 Post subject: Re: Impeller a 2 year maintenance item?
PostPosted: Mon Jul 31, 2017 4:53 pm
where are you guys buying your impellers at? Coming up on 200hrs and should probably do this....
2013 A20
PostPosted: Mon Jul 31, 2017 5:12 pm
http://www.bakesonline.com/searchresult ... 913&page=1 - they've been pretty good to deal with.
PostPosted: Mon Jul 31, 2017 7:37 pm
Amazon
PostPosted: Tue Aug 01, 2017 8:30 am
dezul wrote:
Amazon
I haven't considered doing anything with my impeller. Is this a universal part for most boats or is it specific to our boats? I should probably order one and keep it on the boat.
PostPosted: Tue Aug 01, 2017 10:58 am
gtoddh wrote:
dezul wrote:
Amazon
You might want to start thinking about the impeller as it's probably the most important part of the boat beside the battery
PostPosted: Tue Aug 01, 2017 12:53 pm
The impeller feeds water to the engine water pump. If the impeller fails the engine will overheat. It's a fairly common item and our are pretty easy to replace.
It can last more than one season, but if it fails on the water you either need to know how to replace it or that's the end of your day.
PostPosted: Sun Aug 06, 2017 7:40 pm
If you go by the engine manual it's 100 hrs.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 65 guests
