It is currently Fri Oct 30, 2026 2:40 pm
 Post subject: Does the 330 motor from 2013 have knock sensors?
PostPosted: Thu Jun 15, 2017 9:57 am
Finding conflicting information in older posts so I figured I would start a new one...
Had the boat at the dealer and they did an update...now I am seeing codes 65551, and 65552....for two knock sensors.
From older threads I am reading that this may be a software issue and there are not knock sensors on my boat? Just want to confirm as the dealer I use for service is a decent distance and the rabbit hole with the local dealer for parts could get deep if I'm trying to get something that doesn't exist.
 Post subject: Re: Does the 330 motor from 2013 have knock sensors?
PostPosted: Thu Jun 15, 2017 12:54 pm
no knock sensors, just brass plugs.
PostPosted: Thu Jun 15, 2017 6:13 pm
My 2014 doesn't have knock sensors.
PostPosted: Thu Jun 15, 2017 7:16 pm
Ok good. Confirmed with indmar as well and the dealer loaded the incorrect ecm
PostPosted: Fri Jun 16, 2017 5:40 am
Fail
PostPosted: Sun Jun 18, 2017 8:44 pm
My 2012 with the 330 definitely has knock sensors that attach to the engine plugs. Sounds like you got it figured out though.
Users browsing this forum: Google [Bot] and 35 guests
