It is currently Wed Nov 05, 2025 2:39 am
 Post subject: RGB lighting
PostPosted: Wed Apr 05, 2017 4:07 pm
I'm going to some RGB speaker lighting for a spring boat project and was wondering what wire and connectors everyone here found that worked the best and didn't break the bank. I'm going to light the 4 Icon 8 tower speakers and bought XS650's with RGB to replace the 65's then planned on the wet sounds rgb controller for now.
 Post subject: Re: RGB lighting
PostPosted: Thu Apr 06, 2017 11:39 am
I'd use this wire: https://www.monoprice.com/Product?p_id=13730 (4 conductor 18 awg)
I'd cut these in half and solder one side to the leds and the other side to the wire going to the controller. http://www.ebay.com/itm/10-Pcs-10mm-4-P ... Swn8FXSRAH
Then put a dab of silicone over the solder joint and heat shrink over that.
PostPosted: Thu Apr 13, 2017 9:28 am
Just curious how you're wiring everything together, are you going to run the RGB wires together in series to an already existing wire to give them power or are you running each LED strip back to a controller individually?
I'm thinking about doing LED cupholders and really not sure how to power them. I know there's a better way than running all 16 cup holders directly to the interior lights switch. I'm just not sure how to do it properly?
PostPosted: Fri Apr 14, 2017 11:36 am
You will wire in parallel. Run a couple of "mains" from your controller to your rgb zones, then branch off of those to each particular rgb location. Think trunk of tree to branches.
PostPosted: Sat Apr 15, 2017 8:44 am
I like kinda get it, and I see wiring diagrams, but I don't like real world get it. How do i connect the wires physically together in a chain? Splice? Twist on connector? Butt connector? A pic would be really really helpful.
I was thinking about hooking into my interior led wiring and just using that switch and forego RGB.
PostPosted: Mon Apr 17, 2017 2:47 pm
butt connectors will work. do the input in one end and several outputs in the other end (original wire plus a few "branches").
PostPosted: Thu Apr 20, 2017 10:50 am
I'm currently doing the same project with my 4 Rev 10's. I purchased the 4 Wetsounds RGB LED rings and the RGB brain/controller. Will be the first time doing a project like this so any help will be great!
PostPosted: Sun Apr 23, 2017 7:38 am
I did this on my old Axis... pay extra for the swivel clamps; as the connectors are pre-wired and you can mount w/o the speaker attached... just my $0.02...
Haven't heard if they've been redesigned, but I had to drill small holes for the wire between the ring and speaker housing... that was nerve racking.
-aha-
