It is currently Fri Nov 14, 2025 6:23 pm
 Post subject: Keel guard length?
PostPosted: Mon Mar 20, 2017 4:36 am
Looking to get a keel guard for 2017 axis. A 20 does anyone know what length I should get? Or what length you have on yours?
 Post subject: Re: Keel guard length?
PostPosted: Mon Mar 20, 2017 7:58 pm
I'm guessing it really doesn't matter, more of a preference, just buy longer than you think you need and trim it if you end up not needing it.
PostPosted: Sat Mar 25, 2017 8:23 am
Interested in why you would do that?
PostPosted: Sat Mar 25, 2017 6:58 pm
Same here
PostPosted: Sat Mar 25, 2017 9:22 pm
Protect the hull when beaching is my guess. I will be looking into one this year as well, our primary lake we boat on is a sand bottom (narrow) and nowhere to anchor up, beaching is the only option.
PostPosted: Sun Mar 26, 2017 7:32 am
I would be more worried about your tracking fins...
PostPosted: Sun Mar 26, 2017 10:02 am
Anchor in front of the beach you would pull it up on?? My boat never touches the beach...
PostPosted: Sun Mar 26, 2017 3:04 pm
There isn't enough room where we boat to do that. The line out to the anchor on he back end could get run over. Our lake has very narrow stretches.
PostPosted: Mon Mar 27, 2017 7:27 am
You could try a Box Anchor, it doesn't need a very long line at all. You can anchor it like directly under the boat or 5 ft out and it'll hold
PostPosted: Mon Mar 27, 2017 8:08 am
80AMT23 wrote:
ndahlberg12 wrote:
r33pwrd wrote:
[quote="ndahlberg12"]Protect the hull when beaching is my guess. I will be looking into one this year as well, our primary lake we boat on is a sand bottom (narrow) and nowhere to anchor up, beaching is the only option.
You could try a Box Anchor, it doesn't need a very long line at all. You can anchor it like directly under the boat or 5 ft out and it'll hold[/quote]
Yup I have done the same with the nose of the boat pointed in so I could anchor closer to the beach.
