It is currently Tue Oct 21, 2025 3:14 pm
 Post subject: Re: Connecting the radio to the ACC switch
PostPosted: Sat Jul 16, 2016 10:42 am
Mine still has interruption. I think it may be the bluetooth module. I will investigate next weekend. My radio nor the 420 shuts off though. I do have one of the first 2014 boats made so it is hard to say.
PostPosted: Sat Jul 16, 2016 9:21 pm
My radio won't play bluetooth until the key is in the "On" position. I hate that I have to listen to regular radio when we are just sitting in a cove. If this works for the bluetooth, I'd be happy to make the change. My boat using a bluetooth adapter from the AUX on my Sony.
2014 A24 w/ LS3
PostPosted: Sun Jul 17, 2016 5:40 am
I just plug my phone into the ws420, imo Bluetooth has a worse sound quality
PostPosted: Sun Jul 17, 2016 7:44 am
+1 All the good radio guys also say the same thing about Bluetooth....
PostPosted: Wed Jul 20, 2016 12:02 pm
I have the bluetooth dongle as well. Mine will play on both sides on the ignition switch ACC or engine run positions but we always have to reconnect the phone and repair the connection when ever we switch key positions. I like the ACC option idea but I have already connected my blue led lights to this toggle switch. So how could I do this?
PostPosted: Wed Jul 20, 2016 4:09 pm
Just tap your bluetooth into the deck power?? Would take a few minutes at most. If you look under the dash there are 2 wires labeled "BT" cut the power and splice the BT side into the deck keyed power. Just make sure and cap the old hot wire you cut.
PostPosted: Wed Jul 20, 2016 7:31 pm
Could you not splice your lights into one of the other switches that operate the interior lights or the swim platform lights.
PostPosted: Wed Sep 11, 2019 6:57 am
Can you move the radio wire on the ignition switch to the hot post of the ignition switch? Or is that an ACC wire that powers more than just the radio when the switch is in the ACC position? We always turn off the perko so battery draw is not a problem.
2015 T23, 350, High Altitude prop, FlyHigh front/rear pnp
