It is currently Fri Nov 07, 2025 12:30 pm
 Post subject: Nautic Logic GPS
PostPosted: Mon May 30, 2016 5:46 pm
Has anyone tried this on a 2016 boat? Way cheaper than the $700 upgrade from the dealer for GPS based speed control.
 Post subject: Re: Nautic Logic GPS
PostPosted: Tue May 31, 2016 8:26 am
I sent pics of the connector to Nautic Logic, there engineers are working on it now. I will keep updates coming.
PostPosted: Thu Jun 02, 2016 5:16 pm
Nautic logic doesn't have anything currently that will work for 2016 Axis boats, they will be working on a solution soon and said I could be a beta tester.
PostPosted: Fri Jun 03, 2016 12:39 am
Curious why you are interested in the GPS speed control. I had PerfectPass Stargazer on my last boat and while at the time I really liked it, I actually prefer the simpler stock system on my A20. It took a while each time I started the boat for the GPS unit to find the satellites, and it just simply didn't work unless it could get a lock (which wasn't 100% reliable depending on how sheltered the lake was). The rider profiles were cool but not cool enough, it takes only a few seconds to set the speed anyway.
PostPosted: Fri Jun 03, 2016 7:16 am
http://www.nauticlogic.com/
Keeps everything stock and simple just unplug paddle wheel and plug in gps.
PostPosted: Fri Jun 03, 2016 7:17 am
It sounds like you had an issue with your gps on your perfect pass system on your last boat. I used a Nautic Logic GPS unit connected to my perfect pass and it worked great. It held speed a lot better than the paddle wheel. I haven't looked into it on the Axis but I know it would work good on it too. The Axis speed controller typically can very +/- .5 while wakeboarding. With the GPS unit, you can get it a little more steady so the surges are as noticeable.
PostPosted: Fri Jun 03, 2016 8:37 am
Honestly I wanted GPS but my boat did not have it.. dealer talked me into giving the paddle wheel a try and I'm glad I did.. it works very well imo. My friend has the GPS perfect pass and it sucks bad imo.
PostPosted: Fri Jun 03, 2016 11:42 am
I'm very happy with my GPS cruise/speedometer and for as little as it cost after the dealer discount I would do it again in a minute .
