It is currently Sat Oct 24, 2026 6:24 am
lovenwlink
Post subject: Re: Oil Change Posted: Tue May 10, 2016 8:43 pm |
Joined: Sat Nov 07, 2015 5:40 pm Posts: 14 Location: Lake Sammamish
Previous boat and the Seadoo I used that Jabsco 12v oil pump to change the oil thru the dip stick. I thought it worked great. You do need to run the engine for a few first to warm the oil and there is a trick to getting the pick up tube all the way to the bottom of the pan (get to the bottom but not push it up, a back and forth motion) otherwise it simply won't suck up all the oil. Make sure you get all the oil out otherwise a chance of overfilling if you simply put in what it supposedly takes.
_________________ 2016 T23 prior 1998 Super Sport Nautique
Users browsing this forum: No registered users and 20 guests |
