It is currently Thu Nov 13, 2025 11:01 am
 Post subject: Re: 2015 Drop in cooler?
PostPosted: Mon May 02, 2016 9:46 am
Thank you for the info. I'll get back with the dealer.
PostPosted: Mon May 02, 2016 10:21 am
I got the biggest ao insulated soft cooler. I think it's the 48 can plus 10-20lbs of ice. Used it in havasu this weekend for first time. Fits perfectly in drop space. Kept ice for over 24 hrs like it claimed. Way better but pricier option. Didn't have the problem of cushion not closing at all like some claim with the iqloo's
PostPosted: Tue May 03, 2016 1:33 am
Quimbola wrote:
Sorry for all of the questions, I just picked up my new 2015 A20. Is the drop in cooler on my build sheet just a little bin in the corner? Not an actual insulated cooler?
Thank you in advance!
The dude is trying to tell you an uninsulated bin is a cooler? Do you look stupid?
PostPosted: Tue May 03, 2016 8:31 am
AJWest wrote:
ThatGuy wrote:
I got a Coleman cooler from dicks for $20 and it fits perfect in the recess under the seat behind the driver....but I've moved my cooler to under the port side dash and prefer it there honestly. Now you don't have to lift a seat off and set it somewhere to grab a drink, just lift the hinged seat back and reach in the cooler. Bonus is having extra weight on port side since I surf regular.
I got the same cooler a few days ago. Fits the recess area in the A24 better and holds more...48qts vs 36qts
Do you have a picture of the 48 qt cooler?
PostPosted: Thu May 05, 2016 1:55 am
I ordered my 2015 A20 last year with the cooler option. It is a soft cooler that fits under the starboard cushion behind the drivers seat. If you don't order the optional cooler then they consider the plastic bin in the corner to be the cooler. I use it for my gloves.
PostPosted: Thu May 05, 2016 11:46 am
The build sheet says "Igloo Drop in Cooler $65".
PostPosted: Thu May 05, 2016 10:42 pm
Go back to the dealer, show them the build sheet, and tell them to either give you the cooler or give you the $65. It's bad enough that you've paid $65 for a $25 cooler. It's even worse that they didn't give it to you.
PostPosted: Thu May 05, 2016 10:43 pm
I didn't get the cooler (I went to Wal-mart and bought it for $25) and I didn't get a plastic bin for gloves.
