It is currently Tue Nov 18, 2025 9:14 am
 Post subject: 2012 A22 PNP
PostPosted: Mon Aug 31, 2015 2:00 pm
Let me start by saying that if this has already been answered then please forgive my in ability to research the forum optimally :)
QUESTION: Has anyone figured out the best set up for the rear PNP bags to drain quicker? I understand that the pumps are what the pumps are. My issue is more so the whole gravity feed part. I have no problem when the water makes it to the hard tanks but dang, getting it to the hard tanks can take forever!
I currently have my elbow at the bottom of the bag (SUMO 900 VSACKS) and I am pretty confident that I do not have any kinks.
Any suggestions or ideas would be greatly appreciated!
 Post subject: Re: 2012 A22 PNP
PostPosted: Tue Sep 01, 2015 7:11 am
Ditch the tanks all together, problem solved
PostPosted: Wed Sep 09, 2015 11:28 am
i like the idea. Do you know how difficult is it to connect the drain hose from the hard tank to the bags?
PostPosted: Wed Sep 09, 2015 2:59 pm
this: viewtopic.php?f=15&t=3082
Others may have done this as well, but to my knowledge it is just Walter and myself so far. I replaced the pumps and hoses, Walter kept the stock pumps and hoses. Either way it is so much better. I wish I would have done this from the beginning.
PostPosted: Wed Sep 09, 2015 7:57 pm
I had the drain pump screwed into the bag but it leaked a little bit, I ended up ordering the bag fittings and quick connects to use on the drain pump and vent hoses, I think I spent about 35-40$ on all of it, I reused the fitting and quick connect from the pnp fill hose, my bags had them glued in and I lost an o-ring somewhere, last weekend I had the x-star rear bags which is said to hold 720#, front tank and under seat sack full, and a 400 behind driver seat with the wicked wakesurf this is what my wave looked like at 10.0
PostPosted: Wed Sep 09, 2015 8:03 pm
Don't the 2012's have only one drain in the hard tank? If so then that's by far 90% of the problem. The other 10% is that even with 2 drain ports in the hard tank a few owners still want it to drain even faster. For me the 2 drain ports are fine even though I have 900's in the rear.
