It is currently Mon Nov 17, 2025 3:41 pm
 Post subject: Board rack - rubber strip
PostPosted: Tue Sep 08, 2015 4:58 am
Have a 2014 A20 with the stock board racks. The rubber strips constantly are coming out. Has anyone else experienced this and what solution did you use to prevent this from happening? Glue??
 Post subject: Re: Board rack - rubber strip
PostPosted: Tue Sep 08, 2015 7:10 am
Having the same problem. I thinking I'm going to try some glue also.
2014 A24 w/ LS3
PostPosted: Tue Sep 08, 2015 1:11 pm
Use a small amount of "gorilla glue" under the strip.
Emphasis on small amount as the glue will expand as it dries.
If you do put too much on there the excess glue is easily removed by cutting with a razor blade.
PostPosted: Thu Sep 10, 2015 10:21 am
Thanks for the tip, I'll try the glue. Does anyone know the mgf of the board rack and where a reasonably priced rubber replacement can be purchased. Thanks in advance.
