It is currently Tue Nov 18, 2025 3:31 am
 Post subject: Radio feed back!!!
PostPosted: Tue Jun 30, 2015 6:34 pm
2013 a22 sp2
Since I bought the boat I have had a terrible feed back, whine, from the tower speakers. I have checked the power and grounds they seem good and clean. Tried messing with the RCA cables. One thing that I have figured out is that it only has feed back if the fuel pump is running! Any ideas? Thanks
 Post subject: Re: Radio feed back!!!
PostPosted: Tue Jun 30, 2015 6:44 pm
Factory cables? Wouldn't a premium shielded set of cables help interference such as this?
PostPosted: Tue Jun 30, 2015 6:49 pm
It is stock as far as I know. Do you happen to know the length so I could grab some new ones in the morning. Trying to get everything ready for the 4th. Thanks AJ
PostPosted: Tue Jun 30, 2015 7:27 pm
If it's just going to the passenger side i just used a 12' length rca cable yesterday for the second amp I installed.
PostPosted: Tue Jun 30, 2015 9:44 pm
Try turning the gain down and see if it goes away...
PostPosted: Wed Jul 01, 2015 5:56 am
Add a new ground wire running from the negative wires on the amps over to the ground bar under the dash. You might be getting a ground loop from a ground differential on the dash ground bus and the amp ground bus. The wire will take care of this.
PostPosted: Wed Jul 01, 2015 10:41 am
I have the same problem on my 2015 a22, the dealer tried all of those things, none of them work, to mask the problem you can put a filter between the amp and deck, fixes the problem however basically just covering it up
PostPosted: Wed Jul 01, 2015 11:50 am
Somebody get up with DaveAnalog on wakeworld or bu crew. He's the guru on all things audio.
PostPosted: Wed Jul 01, 2015 12:18 pm
And more than likely it's an easy fix. Boats much different than cars and a little harder to diagnos the noise
PostPosted: Wed Jul 01, 2015 5:43 pm
I have a 2011 A22 that does the same thing. I have literally tried everything that has been mentioned. Better RCAs, Noise Filters, New Grounds, New Powers and mine still makes the noise. The only thing I haven't tried yet is running new speaker wire from the amps to the speakers, which is my next project. I have just been sick of messing with it, but the noise drives me crazy.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 58 guests
