It is currently Mon Nov 10, 2025 7:07 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 2012 axis a22 no plug and play?
PostPosted: Fri Apr 24, 2015 5:52 am
vanamp wrote:
http://www.amazon.com/Sea-Dog-660040-1-Impeller-Puller/dp/B002FVKBSI
I got this one. With free shipping it was only a few dollars more than bakes.
My impeller was stuck pretty good. With the puller I was able to remove it without damaging it to keep as a spare.
Did you bump the engine once you removed the faceplate? I did and once I found the right angle to get to the impeller and apply leverage, it slid out.
PostPosted: Fri Apr 24, 2015 6:25 am
The boat is stuffed in my garage with tower folded and batteries out on charger. It was just easier to get a puller. It was snowing out earlier in the week so there was no real hurry.
PostPosted: Fri Apr 24, 2015 6:48 am
ya my rear locker doesn't have the hoses like yours if that's factory. not a big deal to add them tho if i get a ballast kit upgrade from looking online.
thanks for the photos.
i do have the hoses up front just not in the rear like that so idk.
PostPosted: Fri Apr 24, 2015 11:42 am
[attachment=-1]uploadfromtaptalk1429897151461.jpg[/attachment]
I am not saying "don't buy one". If you pull yours like you said, then you probably need a puller. I had my boat in the water a couple of weeks ago and then I bumped the key after the faceplate was off. It slid right out. The new one was easy to put in as well.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 48 guests
