It is currently Wed Nov 12, 2025 9:16 pm
 Post subject: SERVICE REQUIRED on display & cruise issues
PostPosted: Thu Apr 23, 2015 8:22 am
i ran into a couple issues on the lake yesterday.
1. when starting to pull a surfer, the boat went back down to idle and "SERVICE REQUIRED" was on the display. in then quickly went away and boat was functioning normal. common issue?
2. the cruise was having a lot of trouble setting even in flat water for surf speeds. it would beep (set) then beep over and over again. prop issue? i'm currently running a 1235 with about 3k pounds. it gets up to speed no problem though.
thanks
 Post subject: Re: SERVICE REQUIRED on display & cruise issues
PostPosted: Thu Apr 23, 2015 9:22 am
What year boat? They were having trouble with the cruise last year.
PostPosted: Thu Apr 23, 2015 9:26 am
2015 A22
PostPosted: Thu Apr 23, 2015 8:00 pm
I would call the dealer and ask them about it. if you are close to the dealer, maybe run it in and have them test it.
PostPosted: Thu Apr 23, 2015 8:17 pm
Sell it to me. I will give you 40k for it right now.
PostPosted: Sun Apr 26, 2015 8:51 pm
U can look at the error if it is a code
just push both gauge buttons and hold for 3 sec and the menu pops up..scroll down to the codes and see if one logged
PostPosted: Sun May 03, 2015 7:45 am
If it was a MIL error it has to do with emissions. Mine has done it 3 times, but only at idle. I bet it's an O2 sensor and am not worrying about it until I go in for break in service.
-aha-
PostPosted: Mon May 04, 2015 11:26 am
Looked my code up. Elevated Exhaust temperature tier 1 for both manifolds. Going to dealer anyway. Will let you know.
-aha-
PostPosted: Mon May 04, 2015 2:23 pm
i checked my codes but there were none logged. it's happened a few times since my last post as well. i just dropped it off at the dealer, i'll post back when they figure out what's wrong.
PostPosted: Mon May 04, 2015 8:22 pm
It will not log them... You have to catch them while the error is active. Luckily I was able to catch a photo of mine. I will keep everyone posted too. Again, mine has only happened at idle speed.
-aha-
Users browsing this forum: Google [Bot] and 70 guests
