It is currently Fri Sep 04, 2026 7:42 am
 Post subject: Amp rack dimensions
PostPosted: Wed Feb 11, 2015 6:20 am
Does anyone have the dimensions of the 2015 A22 factory amp rack?
I'm just bored, trying to draw a layout.
Ridebutter Wakeboard School
Cove Wakesurfers
 Post subject: Re: Amp rack dimensions
PostPosted: Wed Feb 11, 2015 4:19 pm
I would be really surprised if they changed it from the '14s.
PostPosted: Wed Feb 11, 2015 5:38 pm
Hit up Dennis Meyers (@liquidtrendsnorthbay) on Instagram. He should be able to help you out. Not sure if he frequents the forum or not.
PostPosted: Fri Apr 10, 2015 1:44 pm
If it's the same as a 14 then this is about the max you can go. Both Bryce2320 and I built this dimension and it worked well.
PostPosted: Mon Apr 13, 2015 12:48 pm
Thanks for the sketch. Unfortunately the 15 is different, I moved my amp rack to the front of the compartment anyhow. It worked out fine.
Cove Wakesurfers
PostPosted: Sun Dec 20, 2015 1:13 am
Does anyone have T-23? Amp board dimensions?
