It is currently Thu Oct 29, 2026 10:46 am
Post new topic Reply to topic  [ 92 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
 Post subject: Re: 2015 Props
PostPosted: Mon Apr 06, 2015 8:53 am
I hate to really boil it down, but does anyone have any experience with the 2249 vs 2247 Its a microscopic difference, but I'm wondering if the additional cup is better for "grip", holding speed, and top end?
Ridebutter Wakeboard School
Cove Wakesurfers
 Post subject: 2015 Props
PostPosted: Mon Apr 06, 2015 9:15 am
I'm curious as well. I don't have any first hand experience, but based on the info I got from acme the 2247 will be slightly less aggressive than the 2249. (Very slightly)
It's the same cup difference that the 2313 and 2315 have, so others may be able to chime in that have compared those two props.
Least aggressive to most aggressive 15 x 14.25: 2247, 2249, 2391
Least aggressive to most aggressive 15 x 12: 2313, 2315, 2419
PostPosted: Mon Apr 06, 2015 1:14 pm
9333129psi wrote:
I have the 1235 prop on my '15 also. Planing seems to be pretty quick, but I'm a little disappointed at top speed which seems to be around 37mph. I know it's not a race boat, but are there better options for higher speed?
Per my OP I am thinking about getting a 2279 for this very reason-should up my top speed from 38mph to 44mph since my primary use of the boat is surfing and running around. I am fairly confident that I'll be able to get upto surf speed with this prop and my current setup (the possibility that I wont is the only reason I haven't pulled the trigger). My guess is that fully weighted wakeboarding will require me to swap back to my 2249.
Anyone have specs on the OJ Cinco?
PostPosted: Mon Apr 06, 2015 5:58 pm
what are the RPM's at wakeboard and surf speeds with the 2249 and whats your ballast set up?
PostPosted: Mon Apr 06, 2015 6:49 pm
I'm running factory ballast, 750 PnP in the rear lockers, under seat bow sack, wedge and with 8 people I'm at 3800 rpm's at 11mph. I haven't had this setup wakeboarding yet, I'll run it up to wakeboard speed next time I'm out.
PostPosted: Tue Apr 07, 2015 6:55 am
Least aggressive to most aggressive 15 x 12: 2247, 2249, 2391
Least aggressive to most aggressive 15 x 14.25: 2313, 2315, 2419
You have those flipped the 2247, 2249, 2391 is a 14.25 pitch prop. tje 2313, 2315, 2419 is a 12 pitch.
:shock: 3800 rpms for 11mph? what is your top speed? is this with a 2249?
Cove Wakesurfers
PostPosted: Tue Apr 07, 2015 8:09 am
:shock: 3800 rpms for 11mph? what is your top speed? is this with a 2249?[/quote]
2249 prop, 38mph WOT 5200 rpms
PostPosted: Tue Apr 07, 2015 9:21 am
Thanks elc for catching my typo. I edited my posted.
Did anyone else find it interesting that wakemakers lists the 2277 for recreational riding, the 2247 for wakeboarding/wakesurfing, and 2315 for heavily weighted? They are listed like that for each model and engine type lol:
http://www.wakemakers.com/axis-wakeboar ... propellers
PostPosted: Fri Apr 17, 2015 1:43 pm
So does anyone have any experience using any of the 15"x14.25 props for wakeboarding behind a heavily weighted boat. If the boat is barely planning with the 15"x12 would it still plane with the 15"14.24 and just have a higher top speed? Just curious. I know that Nautique went to a 17" prop but they have a 2:1 gear ratio now too.
PostPosted: Fri Apr 17, 2015 3:15 pm
15 x 14.25 will get out of the hole faster and has less top speed than a 15 x 12. The oj 945 is between those, it's 15 x 13. not sure if you saw my post but I liked that prop. although if you are cruising long distances its probably not a great option.
Users browsing this forum: Google Adsense [Bot] and 50 guests
