It is currently Sun Nov 09, 2025 5:01 pm
 Post subject: Re: So I bought a 2015 T22... Now what
PostPosted: Fri Mar 27, 2015 3:39 pm
Really just need help with ballast... I do have the PnP but want to know what to buy from a bag perspective.
PostPosted: Sat Mar 28, 2015 5:44 am
Others say the bigger bags will fit and you don't always have to fill them all the way up. I use the 750s and underbow bag. Another 750 for a small crew in the front center of the boat. If I did have my choice again, I'd get the 1100's for the rear. Make sure the fittings are the 1-1/8th inch fittings, not the 3/4", and be prepared to move the floor drain lines in the rear, I dont think this has changed in how they're routed to make the larger bags fit. Good luck and have fun.
PostPosted: Sat Mar 28, 2015 7:42 am
Get in touch with the admin of this site, he runs boardstop.com. Call him up and run your questions by him. He set you up with the right setup that fits your needs and your boat's capabilities. Everyone of us on here will have a different opinion when it comes to brands. Personally I don't think the brand matters that much. I run Sumo cause at the time, I thought they were best. Then the leaky fitting issue (which has been resolved) happened. You really cant go wrong with any brand. My only suggestion is don't go below 750lbs bags for the rear.
