It is currently Fri Nov 07, 2025 11:17 pm
 Post subject: Steering wheel hub measurements
PostPosted: Tue Jan 27, 2015 3:25 pm
I'm out of state for a little while so I don't have access to my boat. Anyone know if the Axis steering wheel is 2.75" or 2.875"? Thanks.
 Post subject: Re: Steering wheel hub measurements
PostPosted: Tue Jan 27, 2015 6:32 pm
You could try to PM Chattwake. I know he swapped out the steering wheel on an A22 he used to have.
PostPosted: Tue Jan 27, 2015 6:39 pm
Yeah I thought about that earlier, might have to do that.
PostPosted: Wed Jan 28, 2015 8:14 am
Like I said in my pm, unlike the older Axis boats (09-12), the newer models utilize a single center bolt hub mount and I think the wheel / mount is pressed on. I was unable to do the swap on my A24. I have a Nardi wheel that I love. Looks like it's going on the lawnmower now.
PostPosted: Wed Jan 28, 2015 8:49 am
You probably need a 3/4" Tapered Shaft to 6 bolt adapter.
http://www.cpperformance.com/p-386-2-lo ... apter.aspx
Says it's available in different bolt patterns.
There is also some information here, http://shopping.rexmar.com/Merchant2/me ... hubdiagram
So you would need the above adapter or this adapter which is basically the same thing:
http://shopping.rexmar.com/Merchant2/me ... dapt2taper
and this to get from 3-bolt to 6-bolt:
http://shopping.rexmar.com/Merchant2/me ... eerhubmomo
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 57 guests
