It is currently Wed Nov 05, 2025 2:53 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: dynamat'ing your Axis
PostPosted: Wed Jan 07, 2015 9:58 am
For those that want to save even more money on sound deadening, peel and seal from Lowes works pretty dang good.
PostPosted: Wed Jan 14, 2015 5:16 pm
I added the FAE (Fresh Air Exhaust) to my 2014 Axis A24 at the end of last summer. Only used boat twice with it, and it was a big difference in engine noise, and exhaust smell for sure. Overall so far happy with it, however I will say as others have, the wedge is definitely in tight quarters with the FAE unit. Both dropping it down and picking it up are both easiest with a hand under the back of the boat and a hand in the hatch. If you can get up-pressure put on the wedge to release the weight of it, you can get to the pins fairly easy to drop the wedge. We've found it easiest to have someone push the wedge from in the water to both deploy it and retrieve it. Sort of a pain, but I think the benefits to the FAE out-weight the negative for sure. I will say the auto deploy wedge that came out this year would be awesome! ;-)
We pretty much leave the wedge down most of the day anyhow. So its not that big of a deal. One thing we haven't tried because we haven't been out at night is the rear LED's.. They are pretty much blocked and I would imagine not nearly as effective now that the FAE is installed.
I will say my main thing was the smell of the exhaust at surf speed. I have the 409 motor, and not sure if they all stink like this one, but it was pretty bad for folks at the rear of the boat. Kids and adults were complaining about it. It definitely has helped a ton with that issue. My stereo is awesome so wasn't as worried about getting better stereo sound. But that is surely a nice plus too.
Here's some pictures:
PostPosted: Wed Jan 14, 2015 7:18 pm
I have an A24 with 409 plus I've had a 409 in another boat and This is the first I've ever heard about a complaint about exhaust smell. We even sit on the sunpad when surfing...no smell whatsoever. I've been in several Malibus with the 409 and same...no exhaust smell on the sunpad or in the cabin.
PostPosted: Wed Jan 14, 2015 8:29 pm
Thanks for the pictures, that helps a lot.
2014 A24 w/ LS3
PostPosted: Thu Jan 15, 2015 1:39 pm
I have the LS3 and never smell exhaust either. Only thing I didn't like about FAE on my last boat was the spray it created during surf speed. Seemed to impact the wave some, but I did not have surf gates on the last boat.
PostPosted: Thu Jan 15, 2015 6:59 pm
My '14 doesn't have any of the issues you describe with the FAE.
