It is currently Tue Dec 23, 2025 10:17 am
 Post subject: 2014 A24 Axis Review, Wakesize for Wakesurfing and Wakeboard
PostPosted: Fri Jun 13, 2014 8:18 am
I just got my axis if anyone is intersted on looking at how the surfgate works or to see the size of the wake, i go through all the pro's and con's
Cost on this boat with all the options $80,000 i'll be paying that off for a long time!
450HP Corvette engine, and Pretty much every option you can get.
also see http://www.reviewoutlaw.com/review-axis ... oard-boat/
 Post subject: Re: 2014 A24 Axis Review, Wakesize for Wakesurfing and Wakeb
PostPosted: Fri Jun 13, 2014 9:21 am
While I'll applaud your lengthy review there are some things that are misguided. Your boat is not "loaded" with almost every option as you described in case someone is looking at your review thinking that's all that's available. You're missing quite a bit of the better options. The heater does not draw hot air from the engine. The rear seats are not for surfer watching as you describe and is illegal and unsafe to do. Glad you didn't pay $500 for stainless cup holders when most dealers are only charging half or less than half of $500 on a custom order (mine were less than $200). Hope you get your rear ballast sacks soon because the surf wake is much better with them. Enjoy your A24 because I love mine.
PostPosted: Sat Aug 02, 2014 8:50 am
Thanks for the Info AJ , the Heat info i got from the Dealer so i guess they were wrong on that, the $500 i did think that was insane i would have paid $200 for that upgrade if i had that price, I got the Rear Sac's and a front Sac's i got the Sumo straight line since they have the 1in pipe holes for a quick drain and fill. vs others that have a 3/4 and need a adapter still playing around with how much i fill them up to get a good wake size. what speed do you drive when you wake surf? Post a video on youtube on your boat i would be interested in watching it and seeing the differences, in mine vs yours.
