It is currently Sun Oct 25, 2026 11:43 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 Post subject: Stainless cupholder install/mod
PostPosted: Fri Aug 01, 2014 8:49 pm
Wanted to replace the plastic cupholders for stainless. I found a good deal on some quality/reasonably priced SS cupholders on ebay, so I pulled the trigger.
Makes a pretty big difference.
 Post subject: Re: Stainless cupholder install/mod
PostPosted: Fri Aug 01, 2014 8:54 pm
Since owning the boat, I haven't liked the holders on either side of ski pylon. Anyone who puts a beer in there with a koozie ends up pulling out the entire holder. Looking at it, the depth was enough to allow for the larger cupholder to fit. I cut the bottom off a larger black cupholder and used it as a template. Then made the cut on the black plastic (not padding or vinyl). Test fit the larger cup from the bottom as the excess vinyl on top prevents it from seating.
When done, trim 1/4" of vinyl off and you're done. Just go slow and test fit throughout the process.
PostPosted: Fri Aug 01, 2014 8:55 pm
Some more pics
PostPosted: Fri Aug 01, 2014 9:23 pm
Looks very nice! Could you post an ebay link to the ss cup holders?
PostPosted: Fri Aug 01, 2014 10:02 pm
Sure thing- these are for the larger ss holders
http://tinyurl.com/l6d5qgj
These are the smaller ones: I only used 2 (in the bow area).
They don't come with the rubber grip on the inside and I had to drill a hole in middle for water. I also used AJ's method (electrical tape) to keep them secure.
http://tinyurl.com/ko5hxcs
PostPosted: Sat Aug 02, 2014 10:39 pm
Looks good, stainless is a classy touch.
PostPosted: Tue Aug 05, 2014 7:48 am
Here are a couple others I used from Amazon (Big ones fit perfect, smaller ones a little loose but were perfect for the LED rings, allowed room for the wire):
http://www.amazon.com/gp/product/B00911 ... UTF8&psc=1
http://www.amazon.com/gp/product/B0097M ... UTF8&psc=1
PostPosted: Tue Aug 05, 2014 7:52 am
A few in progress pics
PostPosted: Sun Aug 10, 2014 8:56 pm
Here's another finished pic of larger cupholder mod next to ski pylon.
PostPosted: Wed Jul 08, 2015 10:59 pm
Thanks Matt. Did my cup holders including the ski pylon ones with the dremel.
