It is currently Wed Mar 18, 2026 11:13 pm
 Post subject: Wakeboard Rack Issue
PostPosted: Mon Jul 07, 2014 3:54 pm
I have a 2011 A22 that the wakeboard racks will not stay locked into place when going across rough water. I have tightened the bolts to the point where the racks are very difficult to turn by hand but they will still not stay in place. Anyone else have this issue that has come up with a fix?
 Post subject: Re: Wakeboard Rack Issue
PostPosted: Mon Jul 07, 2014 6:16 pm
There is some info on here somewhere about this. Don't quote me but I think they took the pins out and cleaned some of the grease off of them to keep them from sliding down so easy. What is happening is that when you hit the bumps the pins drop down and the rack swings. Hopefully this will help. I will look for the thread and post if I can find it.
Bama Axis
PostPosted: Mon Jul 07, 2014 7:41 pm
Thanks!
I searched and found the previous posting. It sounds like I need to take some brake cleaner and remove the grease from the pin and holes and see if that helps.
