It is currently Fri Mar 20, 2026 2:05 am
 Post subject: 2014 Bluetooth problems
PostPosted: Mon Jun 30, 2014 5:07 am
Has anyone else noticed "noise" coming from the stereo when using the Bluetooth input? I have sound pack 3. I just had the first 20 hour service and the dealer checked it out and said he disconnected the rca's and reconnected them and it sounded fine. I tried it when I got home and it was still the same.
Just for sh#!'s and giggles, I went to radio shack and bought a ground loop filter and installed it between the rca's of the bluetooth and the head unit. No change. I'm going to crawl under the again today and see if I can locate the bluetooth module and make sure the connection is tight. Otherwise, maybe the module is bad? Anyone else with an idea?
2014 Axis T22
 Post subject: Re: 2014 Bluetooth problems
PostPosted: Mon Jun 30, 2014 7:07 am
It may be a bad module, but the sound quality on my bluetooth is worse than USB. Does the noise change with engine RPMs? Do you have 2 batteries?
Ridebutter Wakeboard School
Cove Wakesurfers
PostPosted: Mon Jun 30, 2014 7:37 am
Yeah. 2 batteries and it does not change with engine. It stays the same even in accessory mode.
2014 Axis T22
PostPosted: Mon Jun 30, 2014 7:38 am
I also unplugged the rca's and plugged a 3.5mm jack in and plugged my phone to that and it worked perfect.
2014 Axis T22
PostPosted: Mon Jun 30, 2014 9:06 am
Could be a bad module. With it not changing from battery to battery, or engine off or on, I don't think you have a typical ground loop issue.
They are pretty simple little devices. I'm surprised how much they charge for that option.
Cove Wakesurfers
PostPosted: Mon Jun 30, 2014 10:04 am
Cool. Thanks. I am going to try and follow it up to the module later and see if I can see how it's wired in. If I can I would like to disconnect it and hook to another source and see if the problem persists. Then I'll know. ..
2014 Axis T22
