It is currently Sun Mar 22, 2026 4:39 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: straightline sumo "ring" fix? anybody?
PostPosted: Wed Jun 04, 2014 3:34 pm
Im not use to having lucky but I must have been since several of my bags are from the "problem period" and my fittings tightened up fine without the need for rings.
 Post subject: straightline sumo "ring" fix? anybody?
PostPosted: Wed Jun 04, 2014 5:57 pm
Mine tighten up just fine, but when the bag fills and expands, so does the fitting. Then it pops out.
If I were you, I would get them anyway. It's good insurance.
PostPosted: Thu Jun 05, 2014 5:19 pm
Spoke too soon. Vent on arrow bag is still popping loose.
PostPosted: Thu Jun 05, 2014 5:56 pm
Man that's not good. Mine are working fine after installing the rings.
PostPosted: Mon Jun 16, 2014 6:13 pm
Dang.... My rear 600's started popping out the last two days. Those that have the ring fix... Does it work? Hopefully mine should be on the way in a day or so.
Bama Axis
PostPosted: Tue Jul 22, 2014 2:51 am
How's the fix working out?
PostPosted: Tue Jul 22, 2014 5:45 am
Once I installed mine or has been good to go.
PostPosted: Fri Jun 12, 2015 10:20 am
I hate to bump this but it worth the update. Even after my second bag from Straight lines, it still leaks. Not as bad as before with the rings but enough to get a lot of water out of the bilge each time. Wakemakers has warrantied the second bag as well and now they are sending me a Fly High arrow sac. I told them I was done with sumo till I hear positive reviews from people.
PostPosted: Fri Jun 12, 2015 10:52 am
That's a bummer to hear about the continuous issues but at least wakemakers is making it right. I think you'll be happy with the non-leaky FH bag.
PostPosted: Fri Jun 12, 2015 12:06 pm
The newer ones work for me BUT you have to get the new Straightline 1"NPT to Quick-Disconnect fittings to go along with it. Haven't had ANY leaks on my Bro Stock bags.
Users browsing this forum: Google Adsense [Bot] and 67 guests
