It is currently Sat Oct 17, 2026 3:51 am
 Post subject: Info Toggle won't cycle on 2011 A20
PostPosted: Mon May 26, 2014 9:03 am
After bringing the boat out of storage this year and putting it into the lake yesterday, I went to see if the boat was running at normal temp and to check oil pressure etc. The info readout is on the depth finder position and wont cycle through the rest of the info such as oil press, engine temp, lake temp, air temp??? This summer was the first time I found the battery disconnected from the winterization. That wasn't done in the previous year. I wouldn't think that would have anything to do with it but its the only thing that was done different. Any suggestions of fixes you can recommend I will try. Thx
2011 Axis A20
 Post subject: Re: Info Toggle won't cycle on 2011 A20
PostPosted: Tue May 27, 2014 6:53 am
Maybe the switch went bad or the connection is loose? I always remove my batteries for the winter, so I know it's not due to that.
PostPosted: Tue May 27, 2014 9:11 am
Thanks Ferral, Ill check that tomorrow. I emailed a friend at the dealer and he said it's either a loose wire, bad switch, or bad gauge. Said there's really nothing else that could go bad.
Users browsing this forum: Google [Bot] and 49 guests
