It is currently Thu Nov 13, 2025 2:13 am
 Post subject: My version of the surf gate
PostPosted: Sat May 24, 2014 7:23 pm
Put my own spin on all of the posts on poor gate. Worked out pretty well, just need to add the rubber pipe against the hull and cutting the bolts off for the cam lock clamps.Thanks for all of the input on different posts and R&D from Joey!!
 Post subject: Re: My version of the surf gate
PostPosted: Sat May 24, 2014 7:54 pm
That looks really sharp. Are those bulkhead unions going through the platform?
PostPosted: Sat May 24, 2014 8:45 pm
Nice job!
PostPosted: Sun May 25, 2014 9:39 am
The fittings going through the platform are 1/2 inch thru hull fittings cut to length. I used a schedule 80 threaded coupling underneath to connect them. I had to shape the coupling to fit tight between the fiberglass. To shim the inside face I used a piece of the 1 inch starboard from the surf gate paddle and bevelled it at 17 degrees. All total the fittings were 10 bucks! The thru hull fittings also hold the gate off of the platform when connected so there is no chance of rubbing.
PostPosted: Sun May 25, 2014 12:11 pm
Action shots?
store.kultureva.com
Poor Gate Equiped
PostPosted: Sun May 25, 2014 1:14 pm
Knowing its about exact to the Wicked Wave build, I'm sure it'll throw a great wave. Here are some pics of a 2013, A20 I did a Wicked Wave build for last wk...
PostPosted: Sun May 25, 2014 2:25 pm
Thanks Axissteve. Cleanest looking install that I've seen. The dimensions of your "wave shaping device" are from this forum?
1joeyh if I could duplicate a surf wave like that I'd be smiling ear to ear.
PostPosted: Sun May 25, 2014 5:33 pm
If anyone wants a complete turn key package hit 1joeyH up. He is producing packages at a super reasonable price, just bolt them on and go surf!!
PostPosted: Sun May 25, 2014 9:23 pm
I have buy a gate at 1joeyh and the wave is perfect ... My friends are jalous :)
PostPosted: Mon May 26, 2014 5:50 pm
What cam locks did you use? I like how clean it looks without the unit in place
Users browsing this forum: Google [Bot] and 6 guests
