It is currently Sat Oct 24, 2026 6:40 pm
 Post subject: to senthetic or not
PostPosted: Tue Jul 06, 2010 8:23 pm
Are any of you guys using full senthetic oil ? If so then how often do you change senthetic oil in your boat ?
 Post subject: Re: to senthetic or not
PostPosted: Tue Jul 06, 2010 8:50 pm
dont switch over until the 100hr mark is what indmar told me, after that i will be running AmsOil, until then its the pennzoil marine that is recommended. and i usually change my oil every 40-50 hours. just did my 20 hr first service and i put another 10 on it over the 4th weekend.
PostPosted: Tue Jul 06, 2010 10:19 pm
I was told the same thing. Not sure the reasoning but figured I would go with their recommendation. I have about 80-90 hours on our boat and I have changed the oil twice... I used rotella 15-40, napa gold filter 1069
PostPosted: Wed Jul 07, 2010 5:29 am
I have always ran rotella and papa gold in my malibus. Changed the oil every 50 hours and had over 1200 hours on one. I have only had my axis 2 weeks and have already put 20 hours on it. I figured if I ran synthetic as suggested then I should be able to go longer between changes as you would do with q car.
PostPosted: Wed Jul 07, 2010 10:31 am
Did you use synthetic in your old boat?
PostPosted: Fri Jul 09, 2010 3:19 pm
Nope. Used rotella and napa gold filters.
PostPosted: Mon Jul 12, 2010 10:38 am
I use Delo 15W-40 and Napa Gold 1069 filter, change the oil every 50 hrs.
2010 Axis A22
